"Butch, the fact that you are
"Butch, the fact that you are needing a flywheel and the fact that you mention a torque converter flex plate/ring gear, may infer that you are attempting to use an automotive 5.7L engine in a marine application. (I hope that I am wrong on that)
If this boat is much larger than 21 feet or so, IMO this is not a good candidate for an engine.
Add to that if by chance this is to be raw water cooled, you now have future head gasket corrosion issues, let alone the issues of dished pistons and the automotive camshaft profile for a marine application.
Regarding the flywheel that works for the later crankshaft in the AQ series flywheel cover (bell housing in the auto world);
The one that works would be one from a 1987 and later Camero w/ a standard transmission. Most of these Cameros seemed to use the smaller 153 tooth flywheel.
(seems that there were a few Firebirds that also used the 5.0L and 5.7L SBC engines.... this will may work also)
Some time back, Roger (of MichiganMotors) and I discussed the part number for this. He needed a p/n for the 153 tooth wheel due to the amount of requests for later year model engine replacements in the AQ series V/P boats.
I may have this p/n around here somewhere.
If you run into a wall on this....., contact Roger, or get back to me.
Also, if your area has any ERS (engine rebuilder supply) companies, they may be able to help you.
You don't need a good friction surface on this, so a used f/w that is a little scuffed up will do just fine.
I would definitely install a new ring gear!
Make sure that the person installing it does not allow it to become "Red" hot in any areas. (just my personal take on that!)
