Does the distributor only engage in two places in the full rotation? I marked mine before I removed it to do the intake gaskets job. I even did a quick video on my phone to document the marks I made. Engine has not been touched/turned over since.
i can't get it to engage and fully drop down anywhere near where I have it marked. I rotated it way off the mark and it drops down so I know it's not an issue of engagement. I did it the other way, again way off and it dropped right down.
I marked the top of the ignition module compared to the tip of the rotor which pointed directly at the throttle cable bracket. I kept going back and forth rotating a little "behind" so it would engage while rotating into the correct position.
I can see the slot at the bottom where it engages to the oil pump which goes back to my original question. Does this mean it can only engage in two places? Or do I need to try something different?
Bob
Bob
