"1982 Mercruiser 260 (chev
"1982 Mercruiser 260 (chevy 350 block) rebuilt motor (new block) has approx 280 hrs on it. First off...replaced or rebuilt entire fuel system this summer. New fuel tank to rebuilt carb (rochester quadrajet). Found the points to be bad while setting idle. Replaced points, cap, rotor, plugs and wires. Set all timing and gaps to mercruiser specs. Now I need to slightly advance the timing to get a smooth idle but that creates a knock 3500-4000 rpm. If I retard the timing to get rid of knock, idle is not smooth. I have tried adjusting carb idle screws with no improvement. This should be backwards for broken mechanical advance springs, shouldn't it? Any ideas?"
