timmy66commander
"Hello,
I have 1988 Model 2
"Hello,
I have 1988 Model 270 Crusaders (Chevy 350 cu) and I have a reoccurring problem with the Left motor. I have replaced the left distributor cap 2X this season for miss firing. If you look inside the cap it will have moisture, corrosion (green) and arching (black) spots. The right engine distributor cap will have normal signs of use, (slight brown w/o moisture, corrosion or arching). I have ensured that the gasket is installed between the cap and the distributor but that has not stopped the misfiring. I keep a log book and for the last 3 seasons the Left distributor has had this issue. I have run about 60 hours this season. The screens are in place on the bottom of the distributor. Any ideas?
Timmy
1966 31’ Chris Craft Commander
1988 Model 270 Crusaders"
I have 1988 Model 2
"Hello,
Timmy
