"Happy spring to all. I starte
"Happy spring to all. I started to get my work going on my 84 merc 140 today and to my dismay the engine would not start, no spark. After some investigative work I found that the distributer itself is not turning at all. Now I know there is a gear at the bottom of the dist. that is probly the culprit, my question is this. Whats the worst case scenerio here? Since I was trying to turn over the engine with the dist. not turning would that make my job more difficult as far as engine timing goes? Is repairing the dist. the way to go or is an outrite replacement the better choice? If repairing, is this a job for a rocket scientist or can a backyard mechanic that has always had a fairly easy time of understanding and repairing autos handle the job. Before you answer, I got this boat last year and even tho I am quite sure the block is in good shape ( not cracked) I am not 100% sure.
so I am trying not to spend alot of money on the engine just yet. First I want to get it running so that I can be sure the block is not cracked. Once I know this for sure then I will spend what I have to, to bring it up to par. So I guess the long question is this, what would be the cheapest way to get it runnimg just well enough to know the block is all good? Thanks"
