I have I my boat 2 Borg Warner gears, the boat has now been out of the water for nearly two years for a rebuild. Now the boat is back in the water. The engines has been replaced, but with the old gears.
Now, the starboard gear is not fully disengaging when the lever I in neutral…. It works fine both forward and I reverse, but I neutral it is running along I forward direction but half of the speed in is running engaged idling.
The problem has accrued after the two years out of duty as this was not a problem in the past. What can the reason for this be?? And even more important, how can it be solved
Best Regards Martin
Best Regards Martin
