"Anyone out there ever seen th
"Anyone out there ever seen this before? Went to replace waterpump on 1990 225 Johnson. When I dropped the lower unit, a piece of metal, about 3" square with ragged edges, dropped into the LU from above. The starboard bottom motor mount cover is broken, due to corrosion inside the mount? After looking inside the midsection, I realized that the back-side of where the mount goes is cracked in several places, and I'm guessing the piece came from that area. Here's the question. Can the mount and cover-plate be replaced w/o replacing the midsection, or would cracks behind the mount cause major issues? (exhaust leaks, etc.?) Your help is appreciated"
