golden eagle
Hi guys, with your formidable knowledge of outboard motors I'm sure you'll crack this one in no time. I have a 1995 90 hp Johnson that runs great, I've had it now for twelve years and it's always been difficult to keep it going when started cold. The VRO is disconnected and oil is mixed with fuel in tank. The primer solenoid works good, the primer bulb gets hard when compressed, can hear the fuel circulating to the fuel system. But, I need to start it at least six or seven times before it keeps running without stalling even though it starts in a few cranks every time. I need to keep in fast idle a few minutes before I can take off at increased throttle speeds. And upon starting it does smoke a lot because of oil accumulated in the cylinders, mixture is 50:1. I'm under the impression that motor is not properly fed with fuel upon cold starts, but can't seem to pinpoint the problem, what would be your guess? This problem makes it look and smell like a crappy motor but it isn't. Thanks for your suggestions.
