Different fuel pumps for 55 hp and 60 hp?
lfoshaug
I purchased a new fuel pump for my (i believe 1986) Evinrude 60 hp 2 cyl engine.
I used the pump for two weeks, and then it failed.
Question is, could this be the wrong pump for my engine? Is there a difference between the 55 hp pumps, and 60 hp pumps?
The auction stated that it was:
[FONT=Arial, Helvetica, sans-serif]For Use On Engine Models:1976-1989 25-55HP, non-VRO models.
Replaces:OMC - 0398338,0395713,0394543,0398338,0432451,0433387,0438556
Mallory - 9-35352
Redline - RL7352
It was my understanding that the 55 hp and 60 hp was the same engine? At least very very close?
[/FONT]
Those pumps are simple and relable, often replaced for some reason or another.-------Some of the later 2 cylinder motors have a spot to bolt the pump on directly on the side of the block.--2 hoses go to those pumps.-Perhaps there is an issue with the crankcase pulses that drive the pump.----------Look for a pump for an 83 model or later 48 HP.----Also the commercial models used the direct bolt on version.
Thanks alot. I installed the plug from the old carbs. Engine is running great now. What is the difference between the 55 and 60 hp versions? I got my hands on a much newer 55 hp engine today.
I used the carbs and fuel pump from that one.
