Difference between gen and gen2 outdrive
jake_the_snake
"Hey fellas, I have a mercruis
"Hey fellas, I have a mercruiser 4.3 lxh gen+. Is the gen+ going to be different from gen2? ordering an oil seal and carrier assembly for the top section of my outdrive. Just wanted to get the right ones."
"Ayuh,...
Gen.+ is a Mo
"Ayuh,...
Gen.+ is a Motor designation,...
Gen.II is an Outdrive designation...
If you're workingon the Drive,...
Gen.+ means Nothing..."
"Thanks for all your help guys
"Thanks for all your help guys. I was just confused, and didnt want to order an odd part. got the old gear oil in the bilge problem (oil seal). had to have the gimble bearing replaced a couple of times because the shaft bellow was leaking water. The shop failed to check the rest of the drive. So, now im pulling the leg off and and fixing anything else thats corroded or bad, instead of the shop. thanks for all your help!"
