I have been trying to figure out what the difference is between these two motors and have had no luck. I have looked through every part and number on the motors (using the on line parts catalog) and have found none that are different. They show the same powerhead, carb, manifold, ignition and exshaust. I have an OMC service manual that shows all the same tune up specifications for both models. The only difference that I can find in the manual is that the 25HP full throttle operating range is 4500 to 5500 rpm with power rated at 5000. While the 30HP is 5200 to 5800 with power rated at 5500.
I also have an original 1995 parts catalog that shows some things that the online version does not, which makes things more confusing. It shows a different crank,block, head and carb jets on the 25HP remote models only. While the 25HP sail models and 20 HP models share the same powerhead with the 30HP, Yet everyone I have talked to says that the 20HP, 25HP and 30HP all share the same powerhead.
Any help would be appreciated
