Thank you. The impeller is all I needed. I may go with the other the next time to change the housing and carrier seal.It appears the 5Q05 is more comprehensive. It contains the impeller housing and carrier seal. If all you needed was an impeller change then you're fine with what you did.
Carrier seal needs changing if the top of the plastic seal carrier gets deformed or it leaks / fails pressure test. O reasone to change the housing unless it gets scored up or impeller melts from running dryThank you. The impeller is all I needed. I may go with the other the next time to change the housing and carrier seal.
Yea I probably should have changed it. The top was a little melted. Hard to tell the last time it was changedCarrier seal needs changing if the top of the plastic seal carrier gets deformed or it leaks / fails pressure test. O reasone to change the housing unless it gets scored up or impeller melts from running dry
