Dan Raymer
Last summer my Merc died (1994 Mercury 100 model 1100412PD version ELPTO)
Local mechanic tested and said replace voltage regulator - no go. So next, he said, replace the coil.
Nobody local had the special flywheel puller - you can guess the rest. Used a regular gear puller and a really big sledge hammer, being advised that it wouldn't hurt it. Manual says otherwise. Finally got it off, had broken two flywheel magnets, got a clean used flywheel, put it all back together. It immediately sheared the upper crankshaft key so I pulled the flywheel again (easily came off) and replaced the key.
It started and ran great for about 30 minutes. Actually, it ran better than ever before.
Then it started hesitating and "clunking". Started making a lot more smoke than usual. Whimpered to a halt and now won't start. It turns over and sometimes kicks like it is about to start, but never does.
Maybe it broke the key again, but the engine is turning over so I think not.
Any suggestions (other than RTFM, and don't listen to your friends even if they've been fixing boats for 40 years)?
