diconnect oil injector
[h=2]e: '91 Merc 115 2+2 elimination and premix question[/h]
"As to the conversion to premix,,,,disconnect the oil feed line from the "Y" shaped fuel line and block that passage or eliminate the "Y" altogether. Extend the oil feed line and run it back into the oil tank from the top. This will allow you to see how satisfied you are running the premix and enable you to switch back to the stock system if not. The oil will continue to pump and the pump will not need to be removed. "
this was quoted from Bobbyc a few posts down, totally agree. I think mixing oil in large amounts is a pain, unless your running 6 gal. tanks.
