Hi everyone,
The motor hasn't ran for sometime and after cleaning it up it started fine the first time and has not started since(low compression now).
The top cylinder 60psi, and 90psi in the bottom(checking it cold since it wont start now). I took off the bypass cover and looked at the rings on the top piston(its a pretty limited view). From what i saw they looked okay, I gave them a poke with a screwdriver and they were not seized. I can't get a great view of the cylinder walls either but again from the limited view they did not look scratched up.
Is there anywhere else the low compression could be caused from, or does it boil down to rings and cylinder wall?
I would pull off the head bolts to take a better look but a couple of the bolts are so rusted I know at least a couple of them will snap so I rather look everything else over. Thanks!
