Got a 2012 Premier tri toon with a 350 mag I/O in it. Occasionally, it will cut power and hit a limiter. It will reset if you back out and let it idle again. You do not need to take it out of gear, just let it return to idle. It mostly happens when trying to accelerate from an idle pulling a skier. But it will occasionally do it while up on plane after a bit. The instrument panel will beep occasionally. How do i start to diagnose this system? I read something about some PCM's having a beep system for giving DTC numbers? Any help is appreciated
