Motor maintains good oil pressure until warm and will also maintain pressure above 1300 rpm, but when warm and allowed to idle it will lose oil pressure. Drops from 30 to 0. This is not your typical oil pressure problem from a worn out motor. this motor is not worn out. We inspected the pump and replaced the cover/suction side plate because it appeared warped. There was no change in symptoms. pressure reg valve isn't stuck open.
It seems like an idiosyncratic problem which must have happened to some other Suzuki DF25. I have no familiarity with Suzuki so hopefully someone else has seen this weirdness too???
