Gustavo Molina
To make a long story shortDue to bad fuel, one of the valves got stuck in open position, so engine had not compression therefore it didn't start up!
I was able to remove the piston head without removing the whole motor housing, now that I cleaned the valves and they are moving freely, i don't see how I can install the 2 push rods with the rockers cause it's impossible unless you remove the entire engine off because the motor plastic holder is in the way, so I am guessing that the very top part of the engine needs to be remove.
since I don't have the manual hopefully someone here would tell me what are the steps to remove the engine, if it needs to, that means I have to remove the lower unit to disengage the gear/neutral rod?
Is that is correct? Or I don't have to do all that to install the head/valve with rods back to the engine !
Gus
Miami Fl
Gus
Miami Fl
