Hello - i sheared off some of the teeth of my pinion gear and need to replace it. I think I need to remove the drive shaft to replace the pinion gear, yes? If so, can someone point me to instructions on how to remove the drive shaft? I've removed the impeller and impeller housing but there must be something else needed to remove, to slide out the drive shaft and get to the pinion gear.
Thanks in advance!
Thanks in advance!
