"My df90 will run for a while
"My df90 will run for a while then the temp alarm will go off setting the intermitent fuel injection to drop rpms below 3000. I put my hand on the block near all four cylinders and its not overheating and it's peeing cold. I ran it in from 40 miles offshore at 3000 rmps and if it was overheating I would have blown it. I changed the water pump, changed the thermostat, changed temp sensor, swapped the computer with the stbd engine, and still have the same results. Any thoughts? Are there two temp sensors on it?"
