DF 70hp oil change
kyle57
"Ok well my change oil lighte
"Ok well my change oil lighte came on, so I took a look at the oil and it looked pretty good to me. Should I changed the oil or reset the light."
Have you checked the oil level
Have you checked the oil levelfirst? If you think you have used the motor less than 100 hours and your light came on I would wonder if I reset the oil light correctly at my last oil change. I would go back and read my manual and was sure I was resetting it correctly. If you think it was set correctly and the oil light is telling you it's time for another change I would change it again. Good oil and a good filter is not the place to try to save some money or time. Just my thoughts.
change it
read owners manua
change it
read owners manual how to reset
key on
pull out safety lanyard 3 times in seven seconds
