Df 70 Issues
gbb
I have a Df70 that is only run
I have a Df70 that is only running @ 4200rpm. The primer bulb goes soft but it dosen't seem to matter if you keep pumping it. i checked the fuel filter. There is a warning buzzer that sounds ever 5 sec non stop but no warning lights. Any ideas Thanks
Oil level seems fine. Know wh
Oil level seems fine. Know when you just start the engine and go it will run wide open for about 500 feet. Then drops to 4000rpm. It seems to be straving for fuel. Just tried a new fuel pump with no sucess.
"My 1998 df70 is doing the sam
"My 1998 df70 is doing the same thing. I have changed all the filters, shortened the fuel line, changed the gas, and by-passed my water seperator. I noticed that once I prime with the primer bulb it doesn't stay primed. I really think I am getting air in the line somehow. I have quick disconnect fittings on my motor. I am about to change those next. Please help if you have any ideas."
"(Fuel Anti Siphon Valve&#
"(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
