Df 60 miss fires
bud_k
"My DF60 runs great at idle, h
"My DF60 runs great at idle, however when I start to increase RPM it starts miss firing. It seems to oscillate,firing on all four then missing on all four. I thought at first it might be water in the gasoline. I replaced the gas filters with no luck. I then replaced the plugs. Any Ideas, Thanks BUd K"
"No alarms JIT. However, the n
"No alarms JIT. However, the next day after posting this request the motor started missing constantly on cylinder #3. After troubeshooting this problem I found the coil shorted between the primary and secondary windings. I suppose that when it started to arc insided the coil it was also killing the spark to plug #2 making the engine surge when it fired properly. I had to replace the other coil about 18 months ago. When I talked with the local marinas the technicians told me that they had never seen a coil go bad on these motors??"
"I finally replaced the coil a
"I finally replaced the coil and the engine runs great up to about 3000rpms. above 3000 it cuts on and off about every second, oscillating so to speak. I have replaced the plugs, fuel filters, checked for water in the fuel, fuel flow at the output of the fuel pump is good, although I did not check the pressure. There are no alarms. Thanks"
I took my engine to a Suzuki d
I took my engine to a Suzuki dealer to be repaired. THe problem turned out to be a shorted neutral switch. This signaled the computer that the engine was in the neutral position not allowing the RPM to rev over 3000rpm.
