DF 50 Overheat
redfishm1
"1999 Df 50 gets a temp warnin
"1999 Df 50 gets a temp warning. New impeller, housing, therm. OK at idle in gear but alarms at 12 to 1500 RPMs. I put a hose on the intake tube when the lower unit was off and flow was great with the therm removed. Stream is weak and very hot. Please help, I need to fish!"
"T-stat is new, couldn't f
"T-stat is new, couldn't find a poppet until I found a parts blow-up. It's located in the mid-section on the bottom of the block (how convenient) and I found some crud in it. Can't tell if the spring is weak or not so I'll just replace it. 90 minutes to get to the bugger. Three trips to the dealer."
"Update I hooked a hose to t
"Update I hooked a hose to the tube that runs to the poppet adjusted the pressure until the poppet released some water ran the engine up to 3000 rpms and no overheat. It peed a real strong stream which it doesn't normally do. The water pump housing has small lines cut into the surface that mates to the impeller, could this lose enough pressure to not pump enough water?"
