DF 140 tach lights and tone while engine is turning over
J
jplklk
Guest
"I have a 2002 DF140 4 stroke.
"I have a 2002 DF140 4 stroke. When I turn the key
to the on position I get 4 lights and a tone. After
a few seconds the lights extinguish and the tone stops...this is normal. However, after this sequence when I turn the ignition key to start I get a tone and 4 lights. The tone stops and the lights extinguish immediately after the engine starts. Once the engine is running everything is perfect. No lights or warning tone. Is this normal? The engine has 500 hrs on it. Also this problem does not occur all the time.
Thanks in advance for any feedback.
JON"
"This message is for just in t
"This message is for just in time.
As I'm turning over the engine with the ignition key the 4 lights are steady and tone sounds. But, once I release the key and the engine is started the lights extinguish and tone stops...
My mechanic says it could be a dirty ground. To answer your question directly, no there are no quick flashes."
"al right here is what u do
t
turn on the key, not start but on
take off the ESS, aka kill switch
pull the button out 3 times within 7 seconds, it should beep
let me know"
Did that...still get lights an
Did that...still get lights and tone as I turn key to start engine. As I mentioned once engine is started no problems. (no lights or beeper) Am I doing any damage to engine if I run it? Or do you think this is only an indicator problem.
i wish i had my manuals but th
i wish i had my manuals but they are on the way to cali
ask landandsea on the hulltruth
Thanks...I'll give it a tr
Thanks...I'll give it a try.
Appreciate your help and responses!
Jon
