DF 140 tach lights and tone while engine is turning over
tx2
"I have a 2002 DF140 4 stroke.
"I have a 2002 DF140 4 stroke. When I turn the key
to the on position I get 4 lights and a tone. After
a few seconds the lights extinguish and the tone stops...this is normal.
However, after this sequence when I turn the ignition key to start I get a tone and 4 lights.
The tone stops and the lights extinguish immediately after the engine starts.
Once the engine is running everything is perfect. No lights or warning tone. Is this normal?
This is the same post as "jplklk" posted in may 07, and I have the exact same problem.(the check engine prosedure starts twice)So,,did you fix
the prob."jplklk"..?? or anyone else have any sugestions???"
"Yes, when you turn key to pos
"Yes, when you turn key to pos 1 this is normal, but it do the same over again when i start the engine...
