Df 140 overheating possibly
C
crabman
Guest
my 140 overheats or at least t
my 140 overheats or at least the motor shuts down and you have to restart it ......this happens if you take it over 4 thousand rpm's for any length of time....it started happening after the dealer replaced the water pump.....there is water coming out of the pee tube but the stream gets weaker at high speeds ......the overheat light comes on and shuts the motor down ....i took the lower unit off and inspected the water pump and appears to be ok
