"Hey,
Working on a 140. Had
"Hey,
Working on a 140. Had some water in the fuel but cleared it out and replaced fuel water separators and low pressure filter. Seemed to be running better but only right after I cleared the filters and re primed with fresh fuel. Then I started having the Check Engine code give me a MAP sensor warning. 3 then 2. Engine is hard to start but once it is going it is OK.
2 questions: 1. could the map sensor warning effect the starting?
2. If i had some bad fuel go through could that screw up the MAP sensor?
Any suggestions would be great.
Thanks,
dd"
"Hey,
Thanks,
dd"
