DF 140 electrical
gary_t
"I just mounted a new 140 on m
"I just mounted a new 140 on my Checkmate. I have no power to the controls. There is power at the fuses,60 & 30, fuses are good, power at the starter. I unplugged the harness at the engine, checked all 16 wires on engine side, no voltage? What could be the problem? The trim button on the motor works. Turn the key and nothing happens. I checked all the wires at the ecu, didn't find any volts. Where does the power go after the main fuses? Can anybody help! Thanks,Gary"
"Hi J-I-T, Thanks for the resp
"Hi J-I-T, Thanks for the response. I have a manual but it's not helping me much. I checked the nuetral switch, ignition switch, It tells how to check the starter relay, but the picture in the manual doesn't match what I have. I think the power has to go through the ignition switch before it gets to the starter relay? The main relay has power to it from the starter(heavy red wire), but none of the four wires coming off it have juice. Do you think this is the problem? Where does the power to the key come from? I bought this motor from a dealer on e-bay. It is supposed to have only 10 hours on it. I'd sure appreciate some expert advice! Thanks G.T."
no power should be on one side
no power should be on one side of the stater relay the whole time
i want to say yellow/red is the key switch power to make the relay energize the relay
so you need to take a test light and start to probe the ends of wires
"I talked to a mechanic today.
"I talked to a mechanic today. He informed me that there is a seperate wire that connects directly to the battery, this wire sends power to the controls. I found the wire, hooked it up, turned the key and it fired right up!"
"Hey, what color is this wire
"Hey, what color is this wire ? Is it seperate of the harness ? Having same issues. Thanks !"
