I have a 2 cycle 2004 Johnson 3.5 hp outboard model J3RSRE that I was doing some maintenance on. I have it in a pail full of water.
It won't start to save my life, not even with starting fluid.
I cleaned the carb clean as a whistle. Twice.
It's getting spark to the plug. Got a new plug anyway. gapped it and and double checked that I am getting getting spark. I used an inline tester as well as grounding the plug out of the hole.
Fuel filter is clear. Fuel is new and good. I found fresh fuel in the line and the carb bowl.
Compression checks out at about 130 lbs.
I did find a sheared flywheel key. I made a replacement while the original ships, but that didn't seem to be the issue. Probably sheered off from trying to start it so damn many times.
If I have any luck at all, its in the beginning, my first attempt of the day to start it. It will burb, and at best run for 2 or 3 seconds. After that, nothing, no burp, no smoke, nothing.
I just don't understand it, she just isn't catching. What do you think I can do from here?
