Delco voyager 1992 electronic ignition
geno
"could someone tell me the tim
"could someone tell me the timing for a crusader 454 with the old delco voyager hei system? thanks, geno"
"Gene, We may have the same HE
"Gene, We may have the same HEI Delco ignition BUT I am nto sure. Regardless, I am at 10 dgerees. Don't forget to place the system into the timing mode by reversing that plug"
"thanks Al- Another gentleman
"thanks Al- Another gentleman told me to set it a 8 degrees as he said it is a little diffent than the factory setting when using the hei---I don't have a plug to reverse,but i have one that fits in a slot and you hook it to the battery--thanks for the reply---geno"
"Hey Gene,
The factory ma
"Hey Gene,
The factory manual I have states the 10 degree setting WITH HEI...
I run 10 degrees as the correct factory spec. Not as a modification.... You may want to check this out further"
