Ottopotamus
First time post and new boat owner.
I got a 1987 Starcraft Islander with a 3.0L and Alpha outdrive for a great price since he couldn't get the engine started and the kicker wouldn't go into forward gear. I got the engine started after new plugs and filing the points. Rather than replace the points, I wanted to upgrade to electronic ignition, figuring it would pay for itself over time and I would have better reliability. I went with the Delco EST over the Pertronix after various forums seemed to indicate the EST was more reliable.
The upgrade kit came with an ‘initial timing connector’ to allow for easy timing. Unfortunately, the timing didn’t change when inserting the initial timing connector while following the timing directions. I checked my wiring 3 times. My google research showed me the most common issue was that the voltage at the coil was too low due since the ballast resistor or resistor wire was not removed. My voltage at the coil/choke is 13.5V while running. Further google research showed that one person with this issue was able to get his unit to go into ‘service mode’ at a higher RPM than idle. Of course, this didn’t help since initial timing is to be performed at idle RPMs.
The Mercruiser manual states the following after the initial timing process:
With timing light still connected, and engine at IDLE, verify that timing did advance to 12° BTDC, (plus or minus 2°). At 2400-2800 RPM maximum (total) advance is obtained and should be 27° BTDC (plus or minus 2°).
This made me think that I can try to time the engine to meet these requirements. This is the process I used:
So with timing set to 13° BTDC at idle and 25° BTDC at max advance, my results meet the requirements of the Mercruiser manual after the initial timing process.
Is there any reason why there would be any issues with the way it is setup now?
Thanks,
Stuart
- Used normal wiring and timed the engine to 12° BTDC at idle (~650 RPMs)
- Checked timing at 3000 RPMs for max advance and was not within 2°
- Adjusted timing to 27° BTDC at max advance
- Checked timing at idle again and was not within 2°
- Adjusted timing to 25° BTDC at max advance and verified timing at idle to be 13° BTDC
Thanks,
Stuart
