"I own a Mercury, small V8 I/O
"I own a Mercury, small V8 I/O Alpa drive, it does not have a closed loop cooling system. The boat has less than 15 hours of operating time. The boat is used in salt water, Indian river lagoon system eastern Florida, and never left overnight in the water. The boat is hauled after each use and the engine is flushed. I use a product called Salt Away that is added to the engine flush. I have been noticing the flow of discharged water from the right bank (looking at the motor) is 1/8 of the flow from the left bank. When I touch the risers there is a noticeable heat difference although both sides are able to be touched without burning. My question is: What products are available to flush the cooling system and remove the scale that is restricting the cooling flow. Thanks"
