"Help if anyone can.I have a 1
"Help if anyone can.I have a 1994 EFI,Mariner 200 h.p.high performance engine.About 1 month ago my wife and I were going fishing,got in and engine started fine,then when I put it in gear it would not take gas it would just die,I did get it to fun a time or two but then after that it would not start again.So I took it to a boat shop,they adjusted some kind of plates and adjusted TPI switch,still it would not run,took it back a second time,this time they put a kit in the fuel pump said we got it ,took it to the river same thing it was very hard to start,Well thought I need to find someone else to fix this thing before I go broke on let's try this.I took it to another mechanic he said that a gasket had been left out from between the fuel pump and where it bolts to the engine,said it ran fine with him so last Friday I go pick it up take it out Sat.Go about two miles it was like turning off the switch.It would hit when you tried to start it.Finally it would not even hit so I took it back to the ramp about two miles with the trolling motor.The mechanic said that he has checked out all the electrical parts,stator,switchboxes and anything else he could everything checked out good.This engine has always started and ran great.I hope someone can give me some ideas as to what might be going on.Oh yes the first mechanic said that the engine has 120# of comp.per cyclinder.Help Help"
