Have a 2002 four winns 298 with twin VP 5.0 GXi with DP outdrives. When I try to fire the STB engine, I have a dead key. The fuel pump will initialize and the engine alarm will beep, but nothing when I go to fire the engine, not even a solenoid click, or reduction in voltage on the volt meter. Operations I have conducted: I have checked all cables and connections, starting at the battery ad verified for continuity and/corrosion: OK. Checked the ignition switch: OK. I have swapped out rely and fuses: OK. I swapped neutral safety switch with other motor: OK. I am stumped, any thoughts?
