well, with good battery she's crackling away happily out of the water and up to 3000 or so with forward engaged (for some load on the crank)....I still need a definite answer about "will a dead/defective battery kill a motor running at high revs/demand", because I want to eliminate oil starve...there were no alarms to indicate an oil supply problem...but I noticed more steam coming from this motor (out of the upper leg port at the rear) after a run at middle revs, than the other motor. She didn't FEEL hot at all...still cool around the base of the housing and upper leg.
When it happens, at revs above say, 4000, sometimes his motor will suddenly start to get louder, that is, like more demand or resistance is being exerted, for a few seconds before this "seizure" takes effect, and if throttled off straight away, will run fine. My ear is acute to any change in the sound of these motors. Would spark deprivation stop one CDi, or all, or all intermittently, creating this "stressed" sound before she stops, ie; drop every 2nd or 3rd spark?
One would think that seizing due to oil starve would be permanent and definite...why would this motor exhibit a hotter condition than the other, when tell-tale is strong? What stops a motor running at 5000 revs in about four seconds? Fuel starve? Would sputter and die more slowly. Oil starve? Would get hot and seize completely. No spark? Would stop instantly, or die over a few seconds...LIKELY...
Thanks for your suggestions people, and happy boating.
