wh1278
I replaced my risers on my starboard 440...lower elbow, 6 inch extension, upper elbow...and used the OSC121 blocking gasket (FWC). These are the green ones from Thermoseal. I was told by calling Thermoseal that you shouldn't put gasket sealer on them, and sure enough they leaked. Not alot, but every time I take the forward drain plug out of the lower elbow I get water (fresh). I then put a little sealer on the circle between the slots and the exhaust, because the manifolds are old, so they are a little pitted. But still leaking...uuuggghhh. So, question is, do I find use the regular "felt" type? They are what I took off the old risers when I replaced. They worked fine. These new age green composite Thermoseals dont adhere (not hot enough at the elbow), and dont fill the gap. Where do I get the older felt type?
