Have a trim gauge always reads 56 degrees up, alarm is on, jump trim pump to raise or lower outdrive gauge doesn't change. Tried switching with a known good sender and slowly turning knob, no change. Have up to 9.5 volts input and should be around 4 or less, only sensor on vessel that has high voltage. Tried swapping the harness from sensor to first plug at trim pump, same thing. Was advised to try the dc converter with another known good one, no change. Pin test shows high ohm reading on that circuit but it fluctuates. Anybody seen something like this before? any advice would be helpful, salmon season opens soon.
