"I have a new D3-190, generati
"I have a new D3-190, generation B engine with DPS drive.
I have recently run into a heavy steering issue that's a bit odd. The steering is lighter and easier with the engine off, then when it's running.
Fluid levels are good, no signs of leaks.
Also when i first started using the engine, if you pushed against the drive while on the trailer with the engine running you couldn't move it. It would push back and maintain it's position. Now with the engine running you can push it around as if the engine was shut down.
Am I looking at a ram, or pump issue?? It used to track straight with no issue at all, and had a very light wheel. Now it wanders with the currents and has a very heavy wheel. Hopefully this is an easy fix, fishing seasons are coming up fast here! LOL
Thanks,
Ryan"
Thanks,
Ryan"
