salmonkiller01
"I have 1989 omc cobra 5.8l.At
"I have 1989 omc cobra 5.8l.At an idle cylinder #4 does not fire.
The carb, distributer , plugs ... all fine.
No abnormal noises comming from the engine , sounds fine.
Pulled the plug grayish brown running perfect.If i pull the plug lead off any cylinder at an idle the engine lopes down, but if i pull the lead off #4 no change.
At higher rpm it runs smooth.
Tested compression cold and it was at 120, other cyliders were with 130-145
Could i have a worn valve seat????
please any help will be appreciated"
