Cylinder heads
"My 5.7 Volvo 2000 engine was
"My 5.7 Volvo 2000 engine was showing some low compression on 2 cylinders. So the cylinder head gaskets were damaged but when my mechanic took the cylinder heads to a machine shop to be fixed, they told him they are in too bad condition to be fixed. Is that possible? The engine is 6 years old and it is the first time it has been opened. I thought this kind of work can be done a few times.
Thanks"
"You probably blew the hhead g
"You probably blew the hhead gasket between the cylinders That allows the flame to cut into BOTH the head and the lock. I hope the block is okay, or...
Jeff"
5.7vortex heads are famous for
5.7vortex heads are famous for cracking at exaust ports.
"Just completed replacing my h
"Just completed replacing my heads on same engine, '00 5.7GSi with 639 hours. #5 cyl was dead and only 40# in #3, burned valves. Decided to replace both sides."
