we boat in north florida, and do not get much of freezing. Boat is stored indoors in climate controlled building.
I'm in the process of installing new manifolds/risers/elbows.
The Cylinder Block Drains, there are one on each side of the block, right above the oil pan. Besides using these to drain all water from block if I had to winterize it, do they help with ANY cooling at all???
The connection to them leak all the time, see item #18
image link below.
Can I just cap the engine where #8 is connected with an NTP cap? and cap the hoses on section #9?
Thank you
Thank you
