lgarofalo01
Hello all. First off, I am new to this site and have been finding a wealth of information. Thanks for that!
I have 1992 Crusader 454XL's in my 34 Silverton Convertible. Can anyone confirm the correct procedure to disable the electronic timing advance when setting initial timing? The manual that came with the boat is for an older series engine. I received a paper from Crusader that shows to disconnect a single wire connector with a single wire near the LH exhaust manifold. The wire is brown coming out of the convulted tubing near the elecronics box, at the quick disconnect connector the wire changes to black and goes back into the convulted tubing.
The confusing part (to me) is that the Crusader rep. I spoke to stated to unplug the pink wire located closer to the distributor cap when setting initial timing, even after I questioned what was in teh Crusader paper. So... is the paper right where I unplug the black/brown wire or follow what the Crusader rep said and unplug the pink wire (Also a single wire) located near the distributor? Any guidance would be very much appreciated.
