Engines are 2002 Captain's choice 350s. Had the injectors on the starboard side checked and cleaned after finding two partially clogged on the port. One of the starboard injectors was stuck open and needed to be replaced. No Crusader parts down here south of the border. Needed part was a Crusader RA087007 which is actually a GM 12567905. But GM only uses it in Marine. It flows 24 lb. hr. and there is no auto part store or junk yard GM equivalent. The injector is a Bosch style, probably made under license. But then I found a Ford injector, part number XF1E-A5B. This is a part that was used on many Ford engines (and is readily available), looks the same (except for color), and flows at 24 lb. hr. with a four hole pintle, just like the real thing. Picked up a junk yard replacement and had it flow tested and cleaned. Engine runs great. If you need a Crusader injector this can be a good (cheap) alternative.
CaboJohn
CaboJohn
