rodster4843
My 350 fresh water cooled fuel injected engine is about four years old and has the red light buzzer set up and goes off ( though intermittently) when engine runs over 1600 rpm's. Belt seems tight, cap's good, full size raw water canister strainer is clean ( but seems not to fill up at times), seems to have a plenty of water exiting both exhausts, thermostat is opening, impeller looks like new, gauge is reading around 150 (even when having the problem) and the water tank is hot on each end but cool in it's center. The P105 raw water pump has a slight drip from the shaft ( about two drops a second ). I purchased a new one and plan to put it on tomorrow. As I've said sometimes it will run fine and when the buzzer goes off it starts missing and we can't run over 4 knots (limp mode). Anyone have any ideas, thanks, Jack
