1987Luhrs29
Hello I have a 1987 Luhrs Tournament with twin 270 crusaders. Port motor is running fine but when cruising at around 3500 rpms after about 30 mins or so the starboard motor starts to lose rpms and fluctuate from around 3000 rpms back up to 3500 rpm. Then after a few minutes of this the rpms start to drop and will die if I don't lower the throttle. I tested pickup tubes spark plugs alternator and fuel filters. I put on a new coil and after putting on a new one I realized that when testing the voltage I am only getting around 3-6 volts. I have a new electronic ignition in it and no ballast resistor. Any help is appreciated
