boomerfishing
One of the twin 2002 8.1L Crusaders in my Pursuit has an intermittent starting problem. When the problem does occur, I get absolutely nothing on the starboard engine when I turn the key. The port engine always starts perfectly. Typically, backing off the key and hitting it again engages the starter. Sometimes this takes a little while, but when the key does engage the starter, the motor jumps immediately to life. I have changed the ignition switch and the Starter Slave Solenoid. There is also a new battery on the engine. The engines look like new with no rust or corrosion anywhere. The problem only seems to occur when I am starting the engines many times in a short period of time.
Any ideas would be greatly appreciated. Thanks.
