I have both engines installed now and have run both. I wanted to do a few test runs before winterizing but a couple of cold forecasted nights "forced" me to winterize yesterday. I probably jumped the gun and they would have been ok. Anyway, I have a few start up issues which I really didn't want to carry into the spring. I suppose I could remove the impellors and do some quick test runs if I wanted. Here's what I've got if anyone has any thoughts:
After buying 3/8" fuel line, it turns out the connection on the fuel cooler is in fact 1/2" which Crusader calls for in the install guide. At the moment, my fuel setup is exactly the same as it was for the 454's with the exception of this new line.
fuel tank (3/8" aeroquip)------>30 micron screen------>10 micron Racor. Out of Racor, 1/2" fuel line home run to fuel pump/cooler.
1) Port engine. Upon initial startup, I had three low voltage codes and a CEL. I cleared the codes and now have run 2x but the CEL is still illuminated and no codes using Rinda scanner. This engine ran within the past week and so I expected it to instantly fire up but it was really hard to start. It probably took 8 tries and me hitting the throttle before it idled ok and I winterized. The exhaust also "popped" a few times as I was trying to start it. That compression sound which is hard to describe. That's bugging me.
2) Starboard engine. This one was also not an instant start but easier than the port engine. On this one, I have no tach but all other gauges work. Tach was working on last run a few weeks ago with old engines. Weird coincidence, but the tach I had @ home also stopped working at some point but I can't recall if it was the this engine, port or both. I had long gaps between running at home and lost track.
It seems like both engines needed more fuel but it was my wife at the helm starting and me working the throttle at the engine, cables not connected. I mention my fuel line setup above in case that sparks anything. From memory, I think they were pretty much touch the IGN and they were running at home. I have the factory anti siphon valve(s) on each fuel tank. Should these be different for a FI engine?
Mark, did you mention that to me before?
thanks
Bob
thanks
Bob
