Crusader 454xl carburetor question
S
sawdust
Guest
Does anyone know which carbure
Does anyone know which carburetor on Holley's website is the OEM part for a 1995 Crusader 454XL (7.4L). The numbers off my carburetor don't match any part numbers on any new carbs I can find. Thanks
Everything I find for '95
Everything I find for '95 models lists only TBI engines. If I go back a few years I find the 454XL with the Holley using a Crusader P/N 46200 which is the 4011 series carb. This number does not cross reference to a current #. I would call Marysville Marine Distributors. They are a Holley distributor as well as a Crusader distributor. They took on some of the original Crusader employees when Crusader left Sterling Heights for Little Mountain SC.
They should be able to help.
Good luck
Rick
"When I replaced for an 83 cru
"When I replaced for an 83 crusader with a quadrajet, the #'s didnt match exactly, but I was told thats due to upgrading the carbs, and making them more universal for engines of diffferent years. Bottom line is everything lined up perfect, and works great. There was one extra vacuum line on the carb, that I had no conection for, so I just capped it."
"sawdust,
I have twin 1989 Ho
"sawdust,
I have twin 1989 Holley Carburators. I orginally looked at buying new carbs however ran into the same problem u had couldn't find specs for my 502CI crusaders. I was going to rebuild them myself with a rebuild kit. Then I read an article on Holley and the rebuild shop! The url is as follows:
http://www.holley.com/CustomSpeedShop/Rebuild.asp I paid about $200 more but well worth it. These guys are extremely knowledgable and nice. When they returned my carbs I thought I bought brand new carbs. Both carbs are matched to each other, sandblasted all parts, new springs and screw. Unbelievable! Well worth the cost vs trying to decide on what carbs to put on your engines"
