Hello,
First time posting a problem on Marine Engine.
I have a 1997 Tiara 2900open powered by twin Crusader 454XLi (100556)fuel injected engines.
Recently I had an issue with the boat stalling, restarting for a couple seconds, then stalling again. This issue was tracked down to a relay mounted on the motor close the the starter. Every time this happened, a brand new, $20 relay would fix the problem.
This issue with the relay has now become a more of a nuisance as it has been happening more often.
There is no way to tell when it's going to happen. It will happen after boat has been sitting at the dock for awhile, while under power, or while idling. It'll be fine for several trips, weeks or days, then be bad, on a second fishing trip for the day.
I have check the plug to the relay, and everything seems fine. Any other suggestions on possible ways isolate the problem with the continual relay going bad?
